3 місяці тому
katharineee katharineee
Seasonal updates in modern shooters often introduce new cosmetics, balance changes, or temporary modes, but some updates go much further by adding layered progression systems and hidden objectives that push players to explore the game differently. Season 3 Reloaded for Call of Duty: Black Ops 7 does exactly that through Operation Broken Mirror, a multi-step Endgame event that mixes exploration, combat, and puzzle-solving into one high-pressure experience.
One of the biggest roadblocks players are currently facing is Step 4, specifically the Deep Cover Activities objective. The challenge sounds straightforward at first, but the game provides very little guidance on where these activities appear or how to complete them efficiently. That confusion has quickly made Deep Cover one of the most discussed topics in the community.
According to the update content, Deep Cover Activities do not appear with dedicated icons on the Tac Map. Instead, they show up as small yellow zones located primarily in the dangerous Tier III Zone. Areas around Trinity Stadium and Winery are the most common spawn locations, making them the ideal starting points for players who want to complete objectives quickly.
A particularly important mechanic is the connection between Toxic Chase Activities and Deep Cover spawns. Completing Toxic Chase missions not only progresses another Step 4 requirement, but also increases the likelihood of Deep Cover zones appearing on the map. This layered design encourages players to combine objectives rather than treating each task separately.
In Call of Duty: Black Ops 7 Account, events like Operation Broken Mirror highlight how Endgame content is evolving beyond simple combat encounters. Players now need map awareness, environmental observation, and progression planning to succeed efficiently. Instead of rushing objectives blindly, understanding spawn logic and event triggers becomes a major part of mastering the mode.
Once inside a Deep Cover zone, the gameplay changes dramatically. Players must locate a hidden prop disguised as an ordinary environmental object. There are no visual indicators or glowing outlines to help identify it. The only clue is a subtle rattling sound emitted periodically from the disguised enemy. This mechanic adds tension and forces players to rely on audio awareness rather than minimap information alone.
When discovered, the prop transforms into a Shifter, an enemy type that behaves similarly to Mimics from Zombies mode. These enemies are aggressive and mobile, but they share a clear weakness: the glowing mouth. Focusing fire on that weak point allows players to eliminate them quickly before the fight becomes overwhelming.
Interestingly, indoor Deep Cover zones often behave differently. Instead of forcing players to search manually, Shifters sometimes reveal themselves automatically inside buildings. This subtle variation changes how players approach different environments and rewards awareness over brute force.
The objective requires four completed Deep Cover Activities to finish the “Shifters in the Mist” challenge. While that sounds manageable, the difficulty comes from locating active zones consistently while surviving in Tier III danger areas.
For many players, optimizing progression during events like this becomes a major priority, especially when juggling unlocks, loadouts, and seasonal rewards. This is why discussions around Call of Duty: Black Ops 7 Account frequently appear in community conversations about Endgame preparation and progression efficiency.
Ultimately, Operation Broken Mirror represents a shift toward more layered Endgame design in Call of Duty. It blends exploration, survival, and hidden mechanics into a gameplay structure that rewards observation and planning as much as combat skill.
https://www.z2u.com/call-of-duty-black-ops-7/accounts-5-35189
